Skip to main content
Version: current
Device-mode
Description
The device-mode is a feature which sets specific limitations on a device, or limits access to specific configuration options. It helps to protect your router and network from attackers who might gain unauthorized access and use it as a gateway for attacks to other networks.
Available device-modes are advanced, home, basic and ros. Device-mode configuration is factory pre-installed on routers (for devices with MikroTik RouterOS v7.17 or later). Advanced (previously called enterprise) mode is configured for CCR and 1100 series devices, home mode is configured for home routers and basic mode is configured for any other type of device. For devices running versions prior to RouterOS version 7.17, all devices use the advanced/enterprise mode.
[admin@MikroTik] > /system/device-mode/print
mode: advanced
allowed-versions: 7.13+,6.49.8+
flagged: no
flagging-enabled: yes
scheduler: yes
socks: yes
fetch: yes
pptp: yes
l2tp: yes
bandwidth-test: yes
traffic-gen: no
sniffer: yes
ipsec: yes
romon: yes
proxy: yes
hotspot: yes
smb: yes
email: yes
zerotier: yes
container: no
install-any-version: no
partitions: no
routerboard: yes
attempt-count: 0
The device-mode can be changed by the authorized RouterOS user, but physical access to the device is required to change it. After changing the device-mode, you need to confirm it, by pressing a button on the device itself, or perform a "cold reboot" - that is, unplug the power. When the change is confirmed, regardless of confirmation mode, the device will be rebooted!
Changing mode of device-mode
[admin@MikroTik] > /system/device-mode/update mode=home
update: please activate by turning power off or pressing reset or mode button
in 5m00s
-- [Q quit|D dump|C-z pause]
If no power off or button press is performed within the specified time, the mode change is canceled. If another update command is run in parallel, both will be canceled.
danger
There are several EOL products which do not "confirm" mode changes with a reset button press. These routers can confirm a mode change only with a power cycle.
In order to protect the device against an attacker who might silently gain access to your router, abuse it with some scripts and simply try to wait until you reboot your router and not even know that at that time you are accepting changes requested by some intruder, you can "update" mode only three times. There is a counter which will count how many update attempts are made and will not allow any more updates. This counter can be reset only when the administrator does power-cycle the router or presses a button when seeing such a warning on mode settings update attempt (same as with accepting any updates).
Changing device-mode settings using Netinstall or FlashFig
Starting from RouterOS 7.22, it is possible to configure device‑mode and protected‑routerboot and other settings.
For more information, see the Netinstall and FlashFig documentation.
Enabling device-mode feature
[admin@MikroTik] > /system/device-mode/update container=yes
update: too many unsuccessful attempts, turn off power or reboot by pressing reset or mode button in 4m55s to reset attempt-count
The following commands are available in the /system/device-mode menu:
PropertyDescription
getReturns a value that you can assign to a variable or print on the screen.
printShows the active mode and its properties.
updateApplies changes to the specified properties, see below.
Available device-mode modes
There are four device modes available for configuration (mode=advanced is the default one), each mode has a subset of features that are not allowed when it is used. Note that there is no mode that has all features enabled. Certain features need to be enabled even if you have "advanced" mode enabled. ROSE device-mode is very similar to advanced mode, but it is made for RDS and similar devices with a wider option to use disks, therefore supporting container installations from the factory. See section "Feature clarification" for more details about what each option means. So, as per the below table it can be seen that "traffic-gen, container, partitions, routerboard" features are always disabled, unless specifically enabled by the admin user.
Feature / PropertyHomeBasicAdvancedROSE
Bandwidth Test (/tool/bandwidth-test)NoNoYesYes
Containers (/container)NoNoNoYes
Email (/tool/e-mail)NoYesYesYes
Fetch (/tool/fetch)NoYesYesYes
Hotspot (/ip/hotspot)NoNoYesYes
Install Any Version (install-any-version)NoNoNoNo
IPsec (/ip/ipsec)YesYesYesYes
L2TP (/interface/l2tp)YesYesYesYes
Partitions (/partitions)NoNoNoNo
PPTP (/interface/pptp)YesYesYesYes
Proxy (/ip/proxy)NoNoYesYes
RoMon (/tool/romon)NoYesYesYes
Routerboard Settings (/system/routerboard)NoNoNoNo
Scheduler (scheduler)NoYesYesYes
SMB (/ip/smb)YesYesYesYes
Sniffer (/tool/sniffer)NoYesYesYes
SOCKS Proxy (/ip/socks)NoNoYesYes
Traffic Generator (/tool/traffic-gen)NoNoNoNo
ZeroTier (zerotier)NoNoYesYes
List of available properties
PropertyDescription
scheduler, socks, fetch, pptp, l2tp, bandwidth-test, traffic-gen, sniffer, ipsec, romon, proxy, hotspot, smb, email, zerotier, container, install-any-version**, partitions, routerboard** (yes | no)The list of available features, which can be controlled with the device-mode option. See section "Feature clarification" for more details about what each option means.
activation-timeout (default: 5m);The reset button or power off activation timeout can be set in the range 00:00:10 .. 1d00:00:00. If the reset button is not pressed (or cold reboot is not performed) during this interval, the update will be canceled.
flagging-enabled (yes | no; Default: yes)The device will perform configuration analysis and if traces of suspicious code are found, flagged mode will be triggered, setting flagged=yes, enabling restrictions described in the flagged=yes. See the "Flagged status" paragraph.
flagged (yes | no; Default: no)RouterOS employs various mechanisms to detect tampering with its system files. If the system has detected unauthorized access to RouterOS, the status "flagged" is set to yes. If "flagged" is set to yes, for your safety, certain limitations are put in place. See the chapter below for more information.
mode: (basic, home, advanced; default: advanced);Allows choosing from available modes that will limit device functionality. By default, advanced mode allows options excepttraffic-gen, container, partitions, install-any-version**, routerboard.** So to use these features, you will need to turn it on by performing a device-mode update.
By default, home mode disables the following features: scheduler, socks, fetch, bandwidth-test, traffic-gen, sniffer, romon, proxy, hotspot, email, zerotier, container, install-any-version**, partitions, routerboard.**
More specific control over the available features is possible. Each of the features controlled by device-mode can be specifically turned on or off.
For instance scheduler won't allow performing any action in the /system/scheduler. The used device-mode disables all listed features, for instance, if mode=home is used, but zerotier is required for your setup, a device-mode update /system/device-mode/update zerotier=yes will be required with physical access to the device to push the button or cut the power.
Advanced example of changing device-mode
[admin@MikroTik] > /system/device-mode/update mode=home email=yes
[admin@MikroTik] > /system/device-mode/update mode=advanced zerotier=no
If the update command specifies any of the mode parameters, this update replaces the entire device-mode configuration. In this case, all "per-feature" settings will be lost, except those specified with this command. For instance:
[admin@MikroTik] > /system/device-mode/update mode=home email=yes fetch=yes
[admin@MikroTik] > /system/device-mode/print config
mode: home
fetch: yes
email: yes
[admin@MikroTik] > /system/device-mode/update mode=advanced sniffer=no
-- reboot --
mode: advanced
sniffer: no
We see that fetch = yes and email = yes are missing, as they were overridden with the mode change. However, specifying only "per-feature" settings will change only those:
[admin@MikroTik] > /system/device-mode/update hotspot=no
-- reboot --
mode: advanced
sniffer: no
hotspot: no
If the feature is disabled, an error message is displayed for interactive commands:
mode: advanced
sniffer: no
hotspot: no
[admin@MikroTik] > /tool/sniffer/quick
failure: not allowed by device-mode
However, it is possible to add the configuration to a disabled feature, but there will be a comment showing the disabled feature in the device-mode:
[admin@MikroTik] > /ip/hotspot/add interface=ether1
[admin@MikroTik] > /ip/hotspot/print
Flags: X, S - HTTPS
Columns: NAME, INTERFACE, PROFILE, IDLE-TIMEOUT
# NAME INTERFACE PROFILE IDLE-TIMEOUT
;;; inactivated, not allowed by device-mode
0 X hotspot1 ether1 default 5m
FeatureClarification of which menus become unavailable to change
bandwidth-test/tool/bandwidth-test /tool/bandwidth-server
/tool/speed-test
routerboard/system/routerboard/settings (except auto-upgrade option)
containerall container functionality
install-any-versionRouterOS will no longer allow you to install RouterOS version below versions listed under the "allowed-versions" attribute.
email/tool/e-mail
fetch/tool/fetch
hotspot/ip/hotspot
ipsec/ip/ipsec
l2tp/interface/l2tp-server
/interface/l2tp-client
partitions/partitions
does not allow changing the count of partitions. If your router is unable to boot, it will still be able to boot into your other partitions. No restriction for crash recovery.
pptp/interface/pptp-server
/interface/pptp-client
proxy/ip/proxy
romon/tool/romon
scheduler/system/scheduler
smb/ip/smb
sniffer/tool/sniffer
socks/ip/socks
traffic-gen/tool/traffic-generator
/tool/flood-ping
/tool/ping-speed
zerotier/zerotier
Allowed versions
Device mode lists in its parameters an argument called "allowed-versions". This is a list of versions which MikroTik considers as secure and which do not include any serious vulnerabilities which could be used by an attacker.
This setting does not depend on the installed RouterOS version and works as a separate protection layer, in order to disallow an attacker to downgrade version step-by-step to reach any known vulnerable RouterOS release. When you upgrade RouterOS to a release where a newer "allowed-versions" list is available, the oldest list will be overwritten. If you downgrade RouterOS, "allowed-versions" list will not change and will remain updated to the latest list. The list is ignored, if device-mode "install-any-version" is enabled.
Flagged status
Along with the device-mode feature, RouterOS now can analyze the whole configuration at system startup, to determine if there are any signs of unauthorized access to your router. If suspicious configuration is detected, the suspicious configuration will be disabled and the flagged parameter will be set to "yes". The device now has a Flagged state and enforces certain limitations.
mode: advanced
flagged: yes
If the system has this flagged status, the current configuration works, but it is not possible to perform the following actions:
bandwidth-test, traffic-generator, sniffer, as well as configuration actions that enable or create new configuration entries (it will still be possible to disable or delete them) for the following programs: system scheduler, SOCKS proxy, pptp, l2tp, ipsec, proxy, smb.
When performing the aforementioned actions while the router has the flagged state, you will receive an error message:
failure: configuration flagged, check all router configuration for unauthorized changes and update device-mode
[admin@MikroTik] > /int l2tp-client/add connect-to=1.1.1.1 user=user
To exit the flagged state, you must perform the command "/system/device-mode/update flagged=no". The system will ask you to either press a button, or issue a hard reboot (cut power physically or do a hard reboot of the virtual machine).
Important! Although the system has disabled any malicious looking rules, which triggered the flagged state, it is crucial to inspect all of your configuration for other unknown things, before exiting the flagged state. If your system has been flagged, assume that your system has been compromised and do a full audit of all settings before re-enabling the system for use. After completing the audit, change all the system passwords and upgrade to the latest RouterOS version.
warning
Starting from RouterOS version 7.17, device-mode restricts SwOS/RouterOS transition for dual-boot; in order to enable: /system/device-mode/update routerboard=yes
